rustystud
- 2,801
- Woodinville, Washington
Well when we break something, we "pro grade" break it....
We pressed off 2nd and this what we found....it now makes sense that it would not slide into second no matter what I did.
As you can see, she is "gudenbroke"...
To recap, This occurred on the drive home, after attempting to shift into 2nd from 3rd at about 15 mph after running for 10 minutes in 5th, second had previously engaged no issue the four or five times we had driven it, and had given no warning signs of failure. It should be noted the previous owner indicated he had "Always" started off in second gear, and seldom used 1st....I know this is an old debate but it's worth noting. We drained decades old trans fluid from it after getting it to the shop that would be best desribed as "Putrid". We found no metal, but there was obvious evidence of overheating on the components.
A few questions,
-What caused this? Poor lubrication? A failed synchro? Operator error?
-What can be done to prevent this in the future?
-We intend on using 40 weight non detergent oil, as we already have purchased some, is this sufficient?
-What TM would have these part numbers/what is the smaller geared piece called?
-Best place to source these parts?
Thanks again for all the support from the SS crew!
-Deno
View attachment 649755View attachment 649756View attachment 649757
That is caused by bad oil. You need a quality oil especially on this gear as it is running against the shaft all the time "except" when it is in 2nd gear. I would "not" use the 40W oil. Get a good 50W gear rated oil or even higher since your in a hot climate. Don't scrimp on the oil ! Not unless you want a repeat of this happening again.
