lol i read all the posts. this is just more me thinking out loud. RetiredWarHorses hit the nail on the head and the truck was starving out. Im a jackass for not verifying the fuel level in the tank. it was indeed sucking air and lost prime. With the lines blown out, the filter replaced, the tank drained and cleaned, clean fuel it started back up. And now its back to running as horrible as it ever did. This truck has NEVER run well since i owned it.
The truck has at least a couple bad injectors. One of them unscrews before the fuel line will break loose... this ought to be a unique challenge. Of course, its not one of the "easy" ones to get to either. Probably why it was never installed correctly in the first place.
I did a chemical "block test" today, head/gasket are good. Ive got to get the injectors or glows out to complete a compression test.
Do you guys remove the lines to get the injectors out? Or just loosen them and push them off to the side?
On my cummins trucks i always remove the lines completely before messing with the injectors, so i don't bend the lines. On this rotary pump it seems like i can't get to the bottom fuel lines without removing the pump itself.
Are you guys removing the entire injection pump prior to pulling the injectors out the heads?
https://www.youtube.com/watch?v=lRdY_xTDRm8&feature=youtu.be
