Armstrong Begone.....
Bdaman
Illinois
The guy at my local Napa thinks if I bring in original draglink we can maybe find a threaded draglink that will fit. So I can adjust length.
Sent from my ONEPLUS A3000 using Tapatalk
Bdaman
Illinois
Our truck was retrofitted with later model steering not unlike Rich and Bdamans trucks. I refer to it as "'80s steering". Not too long after we got it on the road, the input shaft seal began leaking like a sieve. Since I had no idea what it originally came from I ordered a replacement steering box for an '85 W250. Bolted in perfectly! It was also on less turn lock to lock than the one that came off, so it handles a little better now.
The '85 gearbox you speak of. Is it power or manual?
Sorry, got you confused with Bdaman.
In his case, I would recommend what I posted above. :)
michigandon
82
Wake Forest, NC
It is a power gearbox, identical in appearance and fitment to the one that was already there.
I would also make sure that everything was installed properly. In our case, the POs put the draglink on backwards, which resulted in a VERY wide right turn!
