What the heck is this thing on my 6.5 GEP Engine?
beckel
Austin, Texas
So I dug through the tech manuals and cant find any mention of this electrical component. It wasnt present on my 6.2L so hoping someone may know what the function of this thing is. It came as part of the 6.5L GEP power pack. Says riverside manufacturing but no part number. Maybe some sort of electrical noise suppressor??
Thanks!
Lawdog734
128
Colbert, GA
Is it the diode that comes off the IP? I forget the number and what it does, but that's my guess.
Retiredwarhorses
4,445
Brentwood, Calif
One end terminates to ground on an intake manifold bolt on the right side front by the IJ pump.
the other end plugs into the eng harness 54C, it's a fuel solenoid diode.
Retiredwarhorses
4,445
Brentwood, Calif
Thanks alot guys! I see that the same diode is used on the horn circuit.
that is correct. But both of these don't get used unless you have the associated wires in your body harness. Just depends on how new your harness is. You will find it on ECV harnesses, but I have seen it on N/A harnesses as well on later style NA trucks.
rcamacho
914
Bainbridge Island Wa
I’m missing the IP diode on my 1151. 54C is currently unplugged. Anyone have a picture of where the diode ring terminal bolts to the manifold?
Related, dear god why is a 24v diode $150 bucks?
