- 572
- 648
- 93
- East Central Oklahoma
Well I've noticed the engine oil level of my deuce slowly rising and the oil getting thiner, so apparently there's diesel getting in the oil somehow. The FDC is bypassed and the intake heater has a valve on it, so that leaves either the HH or booster pump leaking. (Unless I'm missing something?)
I took the plug out of the bottom of the IP and ran the in-tank pump for awhile but no diesel ever came out, so apparently it's only leaking while the engine is running. Since I don't know which one is leaking, I figured I might as well replace the seals in both of them so I don't have to come back to it again.
After reading through this thread, I ordered a booster pump seal kit from SECO. The price has gone up to $39. (And shipping cost $19!!! Really!? To ship those little parts?!)
And after reading this thread, I'll need to get some HH O-rings from KennyS, or someone... Any suggestions?
That brings me to the main reason for this post... Since I have to dig into this, what other things should I check and what other parts should I replace while I'm in here?
Since the engine runs so good, I'm hoping to avoid removing the IP to do this, but I will if I have to. I don't want to mess up the timing. I'd like to just lift the engine to get the booster pump out, but it sure looks close!
I'm thinking I should replace the oil feed lines to the IP. There's two right? What is a source for good new production ones?
Other than for the turbo, are there any other oil feed lines on the engine?
I might also replace the fuel feed and return lines on the engine. The ones that are on it now are plastic and don't look very good.
And since I'll have to change the contaminated oil, I'm considering going to spin-on oil filters, if I can afford it. I don't like the 15 seconds it takes to build oil pressure.
Any other thoughts or suggestions about any of this?
Thanks!
Thanks!
