Is the warning light blinking with the buzzer, or is it just the buzzer?The buzzer for my parking break wont shut off even when I disengage the parking break. Wondering your thoughts on where to start chasing this down? So even when im driving im listening to that horrible buzzer going off.
No. Likely you have moisture all through it. I'd start by testing the sensors and isolating which one failed. I'd probably replace both and rebuild or replace the air dryer.Will draining the tanks do it?
On a properly operating system, if the buzzer sounds then a warning light should be activated with it. Neither the warning lights nor the buzzer can activate independently of each other. This is controlled from inside the module itself. Pressure switches and the parking brake switch can't cause this symptom, of the buzzer with intermittent warning light, because they would affect both the buzzer and lights. A failing module can also cause a constant buzzer but the other symptom is the key here.Sometimes the warning light stays on and sometimes its off but the buzzer keeps going.
You pushed in the override valve.I am a 1st time 923 owner & just recently The air spring break overide light has come on what is this indicating
