big block 88
17
Topeka/Kansas
Which way is the water flowing to the heater core? Is the hose by the thermostat the OUT flow to the core and the hose in the oul cooler the return?
A1 NHC250 if that matters any.
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
The outlet by the temp sending unit thru the heater core and into the lower housing20161029_190300.jpg
Sent from my SM-G860P using Tapatalk
Another Ahab
4,491
Alexandria, VA
That woulda been priceless. Alas, no, we keep it nearby so we can keep the leaves clear when we drop things.
That's pretty smart, I got to give it to you.
I was working outside in the driveway yesterday, and accidentally smacked against the countersink I was working with and off it went into the dropped leaves under some shrubs.
I was cursing a blue streak (stupid, but I do it anyway; it blows off steam). I decided I'd give it 2-3 solid undivided minutes to try and find it, and then just commit to buy a new one if no luck. The verdict? No luck.
That thing is GONE; it burned me up to go through that.
frank8003
4,984
Ft. Lauderdale, Florida
Go get an antique "B" drive or something and get the huge magnet out of it or at least and old hard drive with those powerful magnets and put a string on it and drag it thru the dirt and leaves.
Tinstar
1,763
Edmond, Oklahoma
Had a shelter for the trucks put up last week. Ran my conduit,wiring, and hung some of the lights today.
Very nice and clean install!
Looks plenty bright too.
Not sure how high winds get there , but I couldn't have something like that open on both ends here.
Really strong winds, like we can get here, can really do damage to Lightweight structures.
Open both ends and it Acts like a Venturi.
Usually tears something up. No matter how much it's tied down.
Another Ahab
4,491
Alexandria, VA
Apparently that shed is rated for winds up to 130 mph; who'd have guessed that?!
Josh
12
Portland, Oregon
Got the trans removed from the truck today. Found 3 of the 6 flex plate to crank bolts had snapped. Got drill them and easy out them tomorrow. Two where loose and mangled the threads but the holes are still round. One was still tight and in good shape. Anyone know what the size of the bolts/TPI are so I can go buy a tap and some new ones? I tried looking in the TM but I didn't see where to find bolt sizes. Any help would be appreciated.
simp5782
9,339
Mason, TN
If it is a NHC250 the cunmins number is 180175. It is a 1/2" x 1.25" bolt. Prob fine thread. Best to get it from cummins parts
DJones
57
New Palestine Indiana
I don't think she could hold up to 130 mph winds but that's what they advertise. If I enclosed all sides I would have to permit it which means 15' off each property line and that wouldn't have worked for my approach with the 5 ton or being able to use the existing concrete that was there. They installed concrete anchors every 3' and mobile home anchors in 7' of the gravel section.
big block 88
17
Topeka/Kansas
Block heater in, new thermostat, coolant filter is in and plumbed but i sprung a leak and had to turn the ball valves off till i can get it fixed. Looks like the one and only hose i was trying to reuse bit me and sprung a leak. Ooooorrrr. My heater core is leaking wont know till i have more light.
The new thermostat made a HUGE difference, it gets to 180* fairly quick and then just stays there no matter how hard i run it. Granted its only 65* here today but i locked it in 3rd and made it spin 2000 rpm up some steep long hills and it didnt break a sweat.
Dad is rigging up a cold weather front for it with wood sheeting wrapped in OD green vinyl.​
big block 88
17
Topeka/Kansas
Heres 2 weeks ago. Took 2 days to get that stump out. The 5 ton refused to give me low range no matter what i tried. After the job was finished i dumped all the air in the tanks and the truck went right into low range. Guess i have a sticky dump valve on the transfer.
Also got the winch working that weekend also. Just required some knocker loose and a BFH and it freed the spool valve right up and works beautiful now.
Josh
12
Portland, Oregon
Your right on the part number. But the bolts I pulled out were 5/8" x 1.25". It is a fine thread, 5/8 x 18TPI bolt. Cummins wants 42 bucks a bolt. Im going to tap the threads another 1/4in to 1/2in into the crank to put a longer bolt.
simp5782
9,339
Mason, TN
Ive got some if you need them. 30$ shipped for all of them.
