Smckerigan
- 14
- 18
- Scottsbluff nebraska
Yup that's what I built. Just my T is in a different configuration but works the same either way. You can air up or air down with ease just set regulator to desired pressure open the feed it'll air up or down to the pressure you have set and then shut off the feed and open the dump and it releases the pressure from the system so it's not constantly pressurized.I don't know if this is the same setup? I ran across this a year ago on a post. View attachment 653299
So do you have to start at the same psi that is in the tires to deflate after the wheel valves open? Adamsoffroadprerformance if you have a thread on the manual setup would you post a link here or start one so we don't clog up their cpu thread.Yup that's what I built. Just my T is in a different configuration but works the same either way. You can air up or air down with ease just set regulator to desired pressure open the feed it'll air up or down to the pressure you have set and then shut off the feed and open the dump and it releases the pressure from the system so it's not constantly pressurized.
I don't think so. You may have to go a little higher to get the wheel valves to open first, then hit the dump valve while the fill is closed.So do you have to start at the same psi that is in the tires to deflate after the wheel valves open?
Sent from my SM-G900V using Tapatalk
Yes please!So do you have to start at the same psi that is in the tires to deflate after the wheel valves open? Adamsoffroadprerformance if you have a thread on the manual setup would you post a link here or start one so we don't clog up their cpu thread.
Please post the link here when you have.I'll start a new thread.
Same as the Eaton CTIS phone tech told me. I believe an LMTV CTIS controller could be used on an M939, but button layoit/orientation is flipped if you are mounting it same as original. I have not tried to communicate with an xMTV CTIS module yet.I was speaking with one of the mil mechanics I know. She said she was able to access the ctis controller thru the main diag port on lmtv A1 with the dana software on the msd. It may only be on the c7 trucks with data bus though.
