I plan to do a good amount of highway driving in my M1010, so the stock TH400 isn't going to cut it. I plan on running 37" takeoffs and keeping the 4.56 gears. I will be hauling about 1500 to 2000 extra pounds of equipment in the back, but the inside of the ambulance shell is completely stripped so that cuts out a good amount of weight. My guess would be around 8500-9000 pounds curb weight (still 500-1000 lbs under GVWR), maybe even less once I cut down on weight some more.
Here are the options I'm considering, I'm leaning towards the latter 2 for the lock up torque converter. And to throw a monkey wrench into the whole equation, I may (or may not) turbo it down the road.
1. Gear vendors overdrive
2. Built 700r4 (already got a TV cable bracket lined up if I go this route)
3. 4L80e + standalone computer
Most threads I've found refer to the NP205 transfer case, will the NP208 in the m1010 change parts needed for the install?
And just to restate it, reliability is a big factor for me. I make very long drives once every couple months and don't want to get stranded several hours from home.
