Bearing prob. If it engages under load while driving it will sound like a hammer snacked it.Mine fan occasionally rattles at idle when the clutch engages also. Wonder if it could be normal?
Sent from my SM-G860P using Tapatalk
Thanks simp!Bearing prob. If it engages under load while driving it will sound like a hammer snacked it.
Not always. It may be not enough to see unless you hook up a dial indicatorThanks simp!
I'll be sure to check it out. I'm guessing if I push the fan back and forth it will show slop if the bearing is going?
A bearing or loose bolts was my first guess too. Under load (1200 rpm+) it engages smoothly with no sound. Looking at it while running I have seen no movement (slop). I guess I will find out come May or June. I am still holding hope it was only partially engaging with the leaky shutterstat.Bearing prob. If it engages under load while driving it will sound like a hammer snacked it.
That or just go to dual electric fans and it will never come on anyway. Its a power robber.A bearing or loose bolts was my first guess too. Under load (1200 rpm+) it engages smoothly with no sound. Looking at it while running I have seen no movement (slop). I guess I will find out come May or June. I am still holding hope it was only partially engaging with the leaky shutterstat.
WOW & no one called homeland security on you !I know this is a little late but I drove mine to work dressed like this for Halloween.![]()
Sent from my webslinger!
I thought about swinging by the airport like I was picking someone up.WOW & no one called homeland security on you !
Perhaps resembles the ground water around their tanks.View attachment 655949 Drained 4 buckets of this s@@@ outta my 5 this morning after refueling yesterday. I let the inconvenience store know of their swill they were selling and said they will refund me--- yeah right
run!!!i know this is a little late but i drove mine to work dressed like this for halloween.![]()
sent from my webslinger!
I am interested also.Hey Simp, would you mind posting up info on your dual elec fan setup and price if thats ok sir.
