Thanks guys.
It is very torquey. You can watch it twerk at 40mph when you open the 4 barrel haha. Fuel mileage does suck, I'm getting Maybe 8mpg. I did end up using the factory 6.2 motor mounts and turns out they did bolt up correctly. The ones Napa got me would not line up though. I had to remove some small braces from the frame and notch the top of it to make the exhaust clear. Those huge cast iron manifolds take up a lot of room.
Don't just rip out the wiring like I did. I cut the wrong wire and didn't have starter solenoid. A few minutes with the test light and I fixed since the wiring diagram I had was wrong. I removed all wait to start light bulb and unhooked the wire that feeds power from the batts to the glow plugs. If you use an alternator that's a 2 wire (one output and one exciter) just connect the exciter wire to the output. It will work fine as long as the connection is tight. Had mine come loose the other day. You will have to go electric fuel pump unless you buy a low profile pump.
The oil cooler is different from the gasser to diesel on mine. My 454 is a 89 mark 4. So I just bought a universal oil cooler and used that. Using the diesel radiator. I was able to make the lower hose for a 6.2 basically fit with some finagling, the did have to notched for the oil cooler lines, and the fan blade where close to the lower line so I tweaked the corners and it's fine. Super hose is just a flex hose. I am 99% sure it's a 28 inch with 1-1/2 on one end and 2 on the other. I can get you a part number if it's still on there if you need it.
