Horn isn't working
doghead
4 Star General /Moderator
1,179
Just looked, yes the parts are shown and identified with GM part numbers in the -34P.
I could not copy the page or I would have attached it here.
Tinstar
1,776
Edmond, Oklahoma
Are the parts shown and identified in the parts TM?
I'm sure they are.
Stuff like that I just search for without looking up exact part number.
There were, when I needed one, quite a few used ones and lucked out and found all NOS GM parts.
Everything, including screws. Plastic was still sealed and very pliable. No rust on anything.
doghead
1,179
No, simply cut it out. You do not need it.
231
Mount Laurel NJ
My horn stopped working once. The way I fixed it was by taking the front grill off and the horn is near the driver's side headlight. There is a connector that allowed the horn to work when I pressed on it, so I got a new connector, soldered everything together, problem solved.
Tdrake1
Plano/TX
I haven't checked right at the horn. I figured if it isn't the diode I'll just have to chase the wires down until I find what it is
