cavetech
- 2
- 0
- Lake City, FL
On my M1078 I have a rotating beacon switch in the top left corner of the dashboard, but no rotating beacon. On the outside back of my cab is a small cannon plug type connector with just a two wire/two hole.
I looked up the cannon plug and it is for a rotating beacon.
Using my incredible deductive reasoning, is the dashboard rotating beacon switch already wired to the cannon plug on the back of my cab just waiting for a rotating beacon?
The plug just has two connections so it must be a simple hot wire and ground wire setup?
What voltage is the plug?
Thanks, Steve
Thanks, Steve
