Adding a tach?
doghead
4 Star General /Moderator
1,173
BTW, 68 mph winds here today!
doghead
1,173
The pic you posted looks to be a non isolated alternator.
That means it's not original and probably does not have the tach output.
doghead
1,173
Look at post 60.
You will see the same threaded hole in the picture I posted there.
Ignore that threaded hole.
doghead
1,173
They were originally.
doghead
1,173
fwiw, there is another schematic that shows the tach wire. Probably a specific schematic for the ice/ste.
doghead
1,173
Yup, schematic E-11
doghead
1,173
I'm between Syracuse and Watertown, eastern shore of Lake Ontario.
Lots of trees down and zero visibility from the 2' of snow we got lastnight(blowing around).
cucvrus
10,082
Jonestown Pennsylvania
DSCF2340.jpgThe tachometer picture I said i would post. This is in the Crown of Thorns M1009. VDO tachometer. I also added the cloth covering to the dash pad about 10 years ago. The dash padding works DSCF2339.jpg great and is fuss proof. I don't have to worry about scratching it of having it crack from the UV exposure. Works like a charm. The Tachometer is a bit crooked by error on my part. I had it out for putting speakers in the dash and it just ended up that way. I only noticed it was crooked after the last screw was tight. Screw it came to mind. It is not the only imperfection. But it runs and drives and that is the most important thing. Happy Holidays. Working in a winter wonderland. In the meadow we can park the CUCV's and pretend they are nice and bright. You'll say are the running? I'll say yes man. I wouldn't have it any other way. Later on we'll retire. Burn some wood in the fire. You know the rest. HA HA.
Ilikemtb999
44
Denver, CO
I mounted a single gauge cup on left side of the column where the turn signal stalk comes out. It houses my boost gauge but could hold any gauge....
firefox
General
51
Berkeley CA
Sorry for the confusion, it was meant for CUCVRUS
Ok, I'll bite. What is that long pipe that looks like an old fashion horn? Have a great Christmas and thanks for all your help thru the year!!!
doghead
1,173
Shift lever?
