M1009 CUCV The Life Of 'Trooper'
Chevybrit
Northern Pasquotank NC
HI Guys
Thought I'd start a seperate thread of the ongoing mission to get my M1009 into a great daily working truck.
I want to start with the current problem first and then I'll add some pics later of the things I'd done so far when i get chance..
Ok I had wondered if the truck doesn't actually get into third gear some weeks ago and read up and had some response earlier and still in the process of fitting a tacho but with driving OTR it takes me away for chunks at a time.
I wanted to check the RPMS for that 3rd gear change but something else happened yesterday that might shed some light on the problem. I pulled up in a parking lot and when i stopped it rolled just a little over the tarmac onto to the grass verge... it was about a 2-3" step. I put it in reverse and could get it back up !!!
I read a bit more on here and someone said it could be the vaccum line issue or the governor or low fluid levels.
Ive just checked the trans case level fearing the input seal had gone and it was overfilled.. fortunately its fine and very clean.
I'll check the transmission level in a minute when the truck warms up but i wanted to ask..
Is this where the governor is?
I'd read that when taking the cover off things fly out... is that correct.
I want to check the nylon gear
Thanks in advance
Chevybrit
Ok, Transmission fluid level didn't even make it on to the dip stick! With that in mind I've put in a Quart and still nothing showing... the how to says you should warm up the transmission? is it sufficient to be stationary and just shift a few times through the box with the brake on or is it best to drive it around for 10 minutes? Is that why my level could be reading extra low?
doghead
4 Star General /Moderator
1,176
Keep filling it until it shows at least.
dougco1
629
Cooperstown NY
As seen in your photo it looks like you have a bad case of "the poor man's rust proofing" going on. A lot of oil says you have some seals leaking; thus the need to add tranny fluid.
cucvrus
10,316
Jonestown Pennsylvania
Yes that cover with the 4 bolts is the governor. But I agree. that transmission is leaking more fluid then it is holding. It is time for an overhaul. Good Luck.DSCF2216.jpgMoney well spent. It is less expensive to do it now. If you run it till it burns up it can take/ruin more parts with it. Up to and including the case.
Assel
Germany Schwarzwald-Baar
nice truck you have there..how long did you run it with not enough transmission fluid? If its now shiftig good then maybe you got away with it....how does the fluid look? red? dark? brown & smelling like it burned?
Tinstar
1,762
Edmond, Oklahoma
I'm wondering why you would let it get that low to begin with.
If it's leaking as bad as it looks, then it needs checked daily if it's driven.
Your lucky it's still working at all.
I would also go to car wash and crawl under a bit and wash as much as you can off.
Maybe you'll luck out and it's just a pan gasket.
Chevybrit
Ive just bought the truck and done maybe 175 to get it home and around 50 at home .. the rest of the time has been spent going over Electrics (relay mod/shorts/gauge faults etc) Brakes and Front end bushes/ball joints steering etc. I'd just gotten to the trans and transfer case no
LastFbody
10
Milwaukee WI
I had an issue similar to this when I first got my truck. It never liked staying in 3rd speed. After checking the trans fluid and seeing that it was perfect cherry red I chalked it up to being how it was with the weird diesel not making natural vacuum but hooked up to a transmission that requires vacuum. Long story short I realized I had a big problem when I almost lost reverse backing up out of my basement garage.. turned out the rear transmission band was toast. Had it professionally rebuilt, and the difference is night and day with a transmission that works properly. You should be able to easily count the gears as you're driving with a th400 that's running properly, even if you have the vrv set for earlier softer shifts. My truck hits 3rd at 40mph on the dot every time, and then stays in 3rd unless it's under heavy load. When it was all screwed up, it would catch 3rd if I let off of the accelerator, but would drop to 2nd doing anything more than feathering the pedal, even up at highway speed.
Chevybrit
Cleaned the spindles up, so i don't see me having a mission in the future to break it all down... They were on TIGHT!
27mm Socket seemed to be a good fit to drive out the Bushings..
Slit the spring pack..
Wire wheeled them and coated with the graphite that someone on here had recommended..
Chevybrit
Still waiting for the Leaf Pack Energy suspension bushes to arrive but i did put the sway bar back on after it got cleaned and painted and now sports the new ES bush kit..
I like the plasticoat paint I've been using and hoping that it is pretty durable ..
Chevybrit
I got a little further with the vaccum issue also and checked the pressure from the pump
(dont know why the picture is cock eyed)
So i got 15in at the pump and also at the modulator ..
I think i read that it should be 20"? I'm wondering if 15" is still functional ??
Comments ??
Chevybrit
I've ordered the Kit to rebuild the Trans and in a few days it should be here.. I think there must be an issue as It definitely DOES NOT shift up to 3rd. The kit includes a new modulator but i don't see it just being that if it shift fine in and out of second every time? I'm getting 15" vaccum at the modulator and compared to other threads this isn't exceptionally low.
Any thoughts would be welcomed..
german m1008
1,317
Rhein-Main Area, Germany
