sermis
- 17
- 38
- Temple, TX
OK I was removing the glow plugs. Three were swollen, one really bad.
On #6 the entire glow plug tip separated from the glow plug. I have removed the injector and my son says that the tip is loose in the hole but we can't get it out. I can't really get my fat arm and fingers in there.....and no way to get my big head in there to see.
Question is if the entire tip is in the hole is there enough room in the chamber to fish it out? I know if it's broken in half just fish it out but he says it will not go into the head far enough to clear the threaded hole to be removed.
If that's the case I was thinking drive in in some more and maybe it will bend enough to clear then fish it out.....well no room for a hammer and punch. Next idea was get a bolt and turn the end down to the size of the tip and screw it in until the tip gives and then fish it out.
Anything in the back of the chamber that can be damaged?
Anybody with a better idea?
