Runaway multifuel 6/20/14
Wolfgang the Gray
36
New River, AZ
According to the Multi-Fuel Engine Truck Operator Manual (Mar 1977), it states "If your STOP control fizzles out on you and won't cut off the engine, here's an emergency way to stop your engine: With brakes ON and transmission in highest gear, let out the clutch and stall the engine."
Of course, it also states when starting the engine to have it in neutral, but couldn't you start it in 5th gear with the clutch in so if it started to runaway on you, all that would be needed would be to 'let out the clutch and stall the engine'? That would seem a great safety measure to ensure your engine doesn't runaway on startup. Is there something terrible that would happen by starting the truck in 5th with the clutch in???
dmetalmiki
2,027
London England
These posts have prompted me (today) to fit ALL the multi fuels in our group with CO2 extinguishers, And make sure ALL the air intakes are loose enough to remove promptly. (they are also now linked to the engine covers by small chains.).
TsgtB
Granbury, Tx
Mine was my fault for not using safety wire on the bridge over the fuel rod. It vibrated itself loose and the pin on the tip of the rod was not making contact to the shut off plate, so it just idled erratically till' i stalled it out and fixed it.
Wolfgang the Gray
36
New River, AZ
Glad there was no serious damage.
