mdemars03
- 0
- 16
- El Paso, Texas
Ok. I have searched and maybe overlooked but I haven't found the answer to figure out my issue yet. My air horn is not working. I know part of the problem, My solenoid doesn't seem to be working and the button on the steering wheel isn't making good contact. The electrical part is figured out. My problem right now is there is no air going to the solenoid. I have working wipers and all other air operated parts seem to work just fine. When I had the solenoid disconnected from the air line and started the truck, I build air pressure just like normal and no air is coming out of the air line that connects to the air horn solenoid. Is there something fairly easy to try and figure out or would it be best for me to just install a plug on the stock air line and add another line directly from an air tank and fix the switch issues? Any suggestions would be appreciated.
