craigc
- 0
- 6
- Des Moines Iowa
Thank you for your help, I've found 3 of the small nuts so far. Is the part of ground cable clamp is from a ground rod kit or from a ground inside the generator and there for a safety issue?Top item is part of a ground cable securing clamp. The nut, is one of millions dropped by people who could not find them again. Its not the only one you will find if you take the whole set apart. Not to worry, if it is important, the problem will show up later, when you least expect it. But it does look like a canopy nut. There are about 200 in the set.
I think 6 gauge copper would be fine for 75 feet for 240VAC 50 Amps with a voltage drop of less than 3% but you can use this calculator to check for yourself. There is 2 ways to use the calculator, "Minimum conductor size" and "Maximum circuit distance". Try them both and I think you'll see 6 gauge should be fine.Craig, that's a cool setup, I want to run a 75 foot cable to my transfer switch on my house. I have read so much about what size cable to use that I'm confused, I think I will need 4ga 4 wire cable for 75 feet running 240volt single phase. How did you figure out what size to use?
Thanks, the cable is a COLEMAN CABLE 01918 6/3 50Ft SEOW 50A 50ft Power Distribution ExtensionReally nice setup with the cable and box. Did you buy local or order in?
I'm going to use the setup for the house, I put in a furnace transfer switch and will run a quality power bar to run a few lights and the TV. We have a gas stove and water heater with all LED or fluorescent lights and its just to expensive to put in a whole house transfer switch right now. We have a great neighbour and I'll connect her furnace up as well if the power goes down for too long.Thanks for that! While I plan to use my 803A for home power, the capability to make power available direct from the unit while not hooked up to the house would be very beneficial.
