thanks. The 14v output from the Niehoff N3135 is max 50amp. 6AWG is more than sufficient to carry that load (at that short length). That said - I'll probably make some 4AWG cables to get it done.I opted for 0 gauge wire myself. I think 6AWG would be pushing it and 8AWG would definitely be too small, IMHO. Only $20 for 25' of 0 AWG so I figured why skimp. Some nice crimp on ring terminals too.
my understanding is the 12v fuse block should come off the bottom battery - not a direct feed off the alternator. I've been told (but don't know for sure) that the battery "condtions" the current from the alternator. The alternator will provide 14v - and will have an occasional minor spike. I don't know if it's true - but have been told and taught to always power equipment at the battery. YMMV.Can the tap be used to feed a 12v fuse panel?
I am specifically thinking of using it with the pulse distribution system 12/24 12v feed. It was installed in some of the hmmwv taping the rear battery but I suspect that was before the 200amp dual voltage niehoff.
I ran a positive and ground (neg) from the rear battery to a small fuse panel. Everything grounded back to the 12v battery . . . .I am about to do this too, and please forgive me as I've read multiple threads and the N3134 documents but want to get it right. I just picked up a switch panel to mount so I can put in some interior lights, and of course I'd like a 12 volt port for a few basic things.
#1 - pull healthy gauge wire from the 14V terminal to the rear most battery (nearest the back bumper) POSITIVE terminal
#2 - run a wire from the rear most battery positive terminal over to a fuse panel.
#4 - run power from my fuse panel to my accessories.
#5 - chassis ground all accessories
Am I missing anything?
the 14v tap is grounded via a jumper to the regulator mount screw When not equipped to suppprt a load.Yes. Just confirmed. It goes to ground.
I thought i understood but now i am confused what to do.
The 8ga tie wraps to the 200amp feed cable and follows the same routeThat blows my mind. I never imagined grounding a positive volt output. Next chore is to find the safest routing for the new cable.
No, unless you have an Ambulance harness.Got it up and running!!! Thanks!!!!
anybody know if there are backup lights housed into the harness already at the NATO plug? I should probably ask that in another thread.
