- 3,860
- 6,074
- MA
Drill two holes in the frame, and mount this up using integrated star washer nuts (like everything else bolted to the frame for grounding purposes).
My only thought is "That's expensive!"Light in the Dark said:I think this is more in line with the quality of the machine it is being bolted to. Thoughts?
http://www.flamingriver.com/index.ph...5/s0003/FR1003
It is expensive, but it appears to be made in a superior way (internal height adjustment of contacts versus side to side rotation switches). It does not advertise as ruggedized, but its inherently vibration resistant due to how it works... which on an 002A isn't the worst thing in the world! They are also touted as waterproof (I assume IP65 but they might be 67... I doubt it though.)... so all around it is a better product. The less expensive model might be fine for some... nothing riles me up more than doing things twice though... especially spending money for the same problem more than once.My only thought is "That's expensive!"
Yes thank you for finding that option. It might be a real good 'in between' upgrade from the stock disconnect to the higher end units.Or something like this, for about half the price. http://www.littelfuse.com/products/...nnect-switches/2484-single-pole-switches.aspx
Just to be clear, there was no disconnect on these units originally.Just picked up a $5 disconnect like the OEM and cut the suppressor out of #1 and she runs again. Not what I wanted to do, but what the budget allows at the moment.
My imagination for a factory looking disconnect is fuzzy...Pictures?I made a cool disconnect and put it right next to my slave connector. Looks factory
