pigpen60
- 127
- 43
- foley/missouri
Sure if you can google link thingy it I'd appreciate it. Thank you.
Yep "THE REMOTE TRAILER DISCONNECT DEVICE", and the lunette extension when pulled by a M113 if they had them. I have neither but got all the other BII.Hey Mules you have any idea if the electric quick release lunette was used with this?
Use lots of lube! I empty my silicone brake fluid into a jug when I bleed my brakes. It works great for stuff like that.Tried to plug trailer into m35 and I couldnt get the plug in. Tight is an understatement .
Why can't you post it to the SS TM section. The basic manual, TM 9-2330-205-14&P, dated sep 1984 with changes is distribution coded A. The suplmentel TM for all the extra crap for the MICLIC might be coded something else, but the M200A1 isn't.If you want the tm, pm me with your email.I can not post here.
The 205 is already posted here in the old original trailer section. I did upload the tracked m200 tm already. The MICLIC tm is the problem with the C code. I don't believe the rules here allow anything to be hosted that is not for general public distribution.Why can't you post it to the SS TM section. The basic manual, TM 9-2330-205-14&P, dated sep 1984 with changes is distribution coded A. The suplmentel TM for all the extra crap for the MICLIC might be coded something else, but the M200A1 isn't.
I don't have the updated 205. Could you upload and post?Exactly. Only A coded stuff can be posted. I saw a lot of the MICLIC here in germany. 82nd Engineers had them and I helped fix a few when I was contracting for the army. There is also at least one change, if not two, to the 205 manual posted in SS. There is also some "non official" info about the new front trailer jack. It's easier to repair, and has lots less parts. Not so sure it's as sturdy, but the parts are available, and the old one not. I used to go get 8-10 at the DRMO and make 4-5 good ones to use as quick swap outs. That way I could repair them when I had time.
I tried uploading a HMMWV tm yesterday and it error-ed out. Something is probably wonky since the last upgrade on the board. I have successfully uploaded the huge tm's before but suspect a gremlin must be at work currently....Just tried to do it. Its too big a file to up load. Almost every TM I have tried to up load in the last 4 days is to big. The new interactive TM's are simply lots bigger. Lets see if we cant do this another way. The change 2 includes the new "Super Single" Modification. Only one tire on both sides. New front jack and some other small changes. Let me see what else we can do.
