- 4,210
- 3,206
- Near Austin, Texas
I bought an S-788 shelter from a junk dealer. In the front tunnel was some sort of machine, completely enveloped in nasty rotted insulation, which he said was a pump because it has a hose fitting on it. I didn't care what it was, I just wanted the shelter and it was super cheap.
On getting it home, I pulled about 60 pounds of deteriorated insulation out of the tunnel, found and removed the bent grounding rod that was jamming the trolley, and was able to slide the "pump" out.
It is a generator!
The hose fitting is apparently so you can run the exhaust away from the shelter.
So, everything I read says the S-788's should have a 3-cylinder M903(A/B/C) in the tunnel.
This thing is a 2-cyl Onan, and there are no data plates anywhere on it.
I am at a loss to figure out what it is. I've searched SS, the web, and RTFM (many of them), but ......
From the pictures, can any of you wonderful generator-savvy folks tell me what it is??
Thanks, and cheers
It is a generator!
Thanks, and cheers
