ubit
- 0
- 1
- ebensburg pa
looking for a fuel tank access cover ( cover for on the floor)
NSN # 2510-01-454-7077
Thanks
Thanks
That's what I'm trying to avoid, but it's looking more like I'll need to go that route.I would drop the tank before I cut into the floor above it. With it down, you can easily see where the sender is on top of the tank.
I've been looking for an excuse to buy another one of those tools for years now. Many times I've had to improvise, or hold part of a hacksaw blade in a vise-grip or something to make cuts in odd locations.I did mine when I separated the body from the frame. I insulated the whole underside of the tunnel as well. It basically is in between the two body support beams. The holes line up with 4 rivet heads at least mine did.
I used a vibrating multi tool with a metal cutting blade. For a surgeon it will be like using a scalpel .
If you do drop the tank. You may want to upgrade the sender/ pickup to the new style if you don't already have one. the old one used a cork as a float.
At least check the sock on the pickup .
Have fun.
Much appreciated. Dimensions are one of the things I'm wondering about myself.I might have a scrap piece, what are the dimensions/measurements of the panel again?
Not yet. Bought all the parts I'll need (gaskets, hoses, grommets, extra clamps, pads, etc), just haven't started the project yet, waiting for better weather, drained 5 gallons of fuel with a siphon, finally figured out how I'm going to jack up the rear to get a 5 gallon bucket underneath before I release the drain plug, get someone to help push another bucket underneath. I have about 15 gallons of fuel to drain and without a lift it's hard to work around.Did you get around to doing this? I seem to have a slow fuel leak most likely from the fuel tank gasket. I see a drop beading off after driving. It does not quite pool under the vehicle when stationary. If you did go through replacing the fuel tank gasket, I would like to get some pointers / tips. Thanks.
Would you be willing to get me one 12" x 12" piece? PM me how much you would want for it. Shipping is to zip code 80241.I might have a scrap piece, what are the dimensions/measurements of the panel again?
