mt4x4
- 2
- 8
- Springfield, Oregon
Last night driving home the truck seemed like it started to shake a little. I have felt this before and it has never really lasted more than a few seconds. This time it started getting worse. I decided i would pull off at the next exit. Just when the exit was in sight i could start to hear noise. I thought it was something with the wheel bearing. I slowed down to about 30 mph till i got to the exit. On the off ramp the truck started shaking almost like the right side was jumping off the ground. I pulled over and stopped right there. My front right tire was hanging off the axle at almost a 45 degree angle held on by only one lug nut that was half way off. Three of the studs were snapped off. I got my jack out and got the wheel off the ground. My first thought was i can just take one off the back. Bet you know how that went. I knew the other side was left hand so that was not going to work. I went for a walk back up the off ramp and got lucky. I found a broke stud with the lug nut on it. The fun part was getting the stud out. I did not have any tools that would grip the stud. a set of vise grips would of been nice. I used the jack under the frame to grip the stud. That worked. The studs that broke off were all together on one side so i could not even get the lug nut on across from each other. the threads were also messed up. I found a file to take the first few threads off so that i could get the lug nut started. This was at about 11:30 pm last night and my cell phone was dead. I got lucky. I manged to drive 3 or 4 miles to my house with the two lug nuts at about 10mph. After getting a charge on my phone i took a picture of what it looked like. Wish i had a picture of it with the tire half way off. I had cheeked all my lug nuts in the summer. I would of never thought they would come loose that easy.
