MEP 803a Glow Plug Wire
Guyfang
23,351
Burgkunstadt, Germany
The info IS in the TM, but was a PITA to find:
Part number is: 88-20540-8, (there is 4-5 other part numbers that will also come up with this type wire)
NSN is: 6145-00-284-0657
6145-00-690-9320
6145-00-578-7512
6145-00-635-4816
As you can see, there are several different NSNs for this wire. It has been manufactured by 4 or 5 different companies. The top NSN is probably the most current NSN.
It is an 8 AWG, but has special characteristics. See below. It is AIRCRAFT grade wire. But any wire that is the right size, and has the temperature rating will probably work. I supose that if you ask at a specialty firm, that deals with wire, the description below would make sense to them. Keep in mind, this wire gets HOT.
AAGRCROSS-SECTIONAL SHAPE STYLEROUND
ABJHTEMP RATING105 DEG CELSIUS
ADVLCROSS SECTION OUTSIDE DIAMETER0 6/25 INCHES NOMINAL
BLNZSTRAND QUANTITY PER CONDUCTOR133 SINGLE CONDUCTOR
CXCWCONDUCTOR FORMSTRANDED SINGLE CONDUCTOR
CXDCROUND CONDUCTOR SIZE8 AWG SINGLE CONDUCTOR
CXDGSTRAND AWG SIZE PER CONDUCTOR29 SINGLE CONDUCTOR
CXFKVOLTAGE RATING600 MAXIMUM ROOT MEAN SQUARE (RMS) OPERATING VOLTAGE SINGLE CONDUCTOR
HUESCOLORWHITE 1ST POSITION COVER SINGLE CONDUCTOR
MATTMATERIALCOPPER ALLOY 101 CORE CONDUCTOR SINGLE CONDUCTOR OR COPPER ALLOY 102 CORE CONDUCTOR SINGLE CONDUCTOR
MDCLMATERIAL DOCUMENT AND CLASSIFICATIONASTM B33 ASSN STD ALL MATERIAL RESPONSES CORE CONDUCTOR SINGLE CONDUCTOR
SFTTSURFACE TREATMENTTIN CORE CONDUCTOR SINGLE CONDUCTOR
STDCSURFACE TREATMENT DOCUMENT AND CLASSIFICATIONASTM B33-63 ASSN STD SINGLE TREATMENT RESPONSE CORE CONDUCTOR SINGLE CONDUCTOR
Daybreak
2 Star Admiral
762
Va
Howdy,
MIL-SPEC M5086/2-8 ( a -9 means white) so M5086/2-8-9
The problem is finding small pieces for sale.
ROUND
TEMP RATING
105.0 DEG CELSIUS
0.240 INCHES NOMINAL
CONDUCTOR FORM
29 SINGLE CONDUCTOR
VOLTAGE RATING
600.0 MAXIMUM ROOT MEAN SQUARE (RMS) OPERATING VOLTAGE SINGLE CONDUCTOR
COLOR
MATERIAL
SURFACE TREATMENT
FREQUENCY RANGE
9.000 GIGAHERTZ MINIMUM AND 10.500 GIGAHERTZ MAXIMUM
Guyfang
23,351
