Center mount intercooler?
Ilikemtb999
45
Denver, CO
Like a Subaru? I think space will be difficult with something like that. There's plenty of room up front and you'd have plenty of room to pipe it. I also don't think an IC is going to do much on these engines with little boost.
The FLU farm
1,442
The actual midwest, NM.
There might be more to the story, including lots of boost, that we don't know about.
If noting else, by definition an inter cooler goes between two power adders (such as a turbo, then an inter cooler, then a blower), which is where the "inter" comes from.
In a single power adder application, such as a turbo, it's merely a charge air cooler.
Most of up front space has oil, and trans coolers, and electric fans in it. I was avoiding putting the "inter boost charge air to air cooler" down low or out front to avoid road damage.
Anything I can do to lower eggs and up power is good. I have added a better ylturbo etc, as in my signature if you can see it. Eventually I might have injection pump enough to run boost in the 20's. If I put on the intake and put a big ol' honking, butt ugly hood scoop over it, it should fit.
My wondering is if there is a kit to do this.
Ilikemtb999
45
Denver, CO
You don't have anything in your signature. There is no kit that I've seen for that. I think you'd just have packaging issues up top. My old wrx had a ton of room up top due to the flat 4 engine. I don't see behind the grill to be a weak spot, many trucks and cars put it in that location.
i think I'd do meth injection over an IC
ken
26
Houston Texas
I've tried boost in the 20"s. 22 to be exact. Your head gaskets wont be thrilled with the idea. You will need to use 18 to 1 aftermarket pistons. I've had better luck with removing/reducing flow restrictions for adding power. Then you can increase the fuel rate while removing the heat out the exaust. With turbos, less backpressure is better. A intercooler may restrict airflow enough to cancel itself out.
gimpyrobb
dumpsterlandingfromorbit!
27,786
770
Cincy Ohio
Ken, you prefer pistons to thicker head gaskets? I've been toying with going the head gasket route on my 6.5.
This is my truck:
86 CUCV, 6.5 Navistar, ARP Studs top and bottom, HX40WII Turbo, 3 into 4 into 5 inch exhaust, Exhaust manifolds and ports ground to match, 14 ply 9-16-36 bias ply tires, H.O. Water pump, Hi CFM fan, 4 cored industrial radiator, Remote oil cooler, Dual alts, 4L80E transmission, Twin sticked NP205, 2 transmission coolers, 4010 u- joints, Water methanol injection, Rebuilt injection pump and hi pop injectors, Steering cooler in radiator, Detroit locker, Dual tanks, fuel pumps and filters, Oil, Trans, Water temp gauges, Pyro, Tach, Boost gauges, Oil press, Fuel press, Volt gauges, Trans press gauge.
