mijoe
- 4
- 8
- Tallahassee, FL
Hi All, This board is full of great info and was very helpful as I went through the purchase process. Now that I have my MEP-803a, I built a load bank with 8 heater elements in a barrel to put it through its paces. I have noticed two issues that I have not found a ton of information on, and was hoping to run them past the fine folks here. First, I have noticed that the utilization meter moves around a little on a constant load (water heater elements), which I did not expect. I am wondering if it is associated with the fact that I cannot get the voltage regulator above 230 or so, even when rotated to the stop. I read somewhere that I may need to clean that rheostat to fix the issue... sound correct? Secondly, the oil pressure continually drops as the machine runs. At startup, the oil pressure is around 40, but I have seen it get as low at 17-18 after running for about an hour. Is this indicative of a specific failure on the unit? The unit is a 2005 model with 620 hours. I am running Rotella T5 15w40 in it currently.
Any advice is appreciated!
