6.2 or 6.5 engine ?
Chief_919
100
Western NC
Can't say for sure with that picture but the emissions sticker is typical of GEP 6.5's.
doghead
4 Star General /Moderator
1,179
Looks like a 6.5.
Wire Fox
161
Indianapolis, Indiana
Everything's more vivid and clean than my engine, that's for sure. Otherwise, looks the same as my 6.5 GEP. I'm trying to wipe everything down as I go through and work on different portions of the engine, since it makes a big job feel a little easier...
86humv
501
Texas
Your 6.5 is a de-tuned motor.
The 6.5 with a 4L80e trans is not de-tuned, and has a different injection pump , water pump, and eng. harness.
6.5 turbo also has a diff. Inj. pump heads, manifolds, and eng. harness as the other two.
Wire Fox
161
While I'm 100% that the part numbers are different, isn't the injection pump for the 6.5 NA detuned and 6.5 NA the same, except that the 6.5 NA detuned pump has the flow rate dialed down from the factory? This one's really for my own confirmation, because I really don't want to think about also buying a new injection pump right now while doing my 4L80E upgrade... I've spent enough money already before even getting to the "high maintenance" part of HMMWV.
Retiredwarhorses
4,184
Brentwood, Calif
correct Greg...the 6.5NA in the 4L80E equipped trucks have a lot more felt torque and HP.
