- 10,337
- 6,285
- Camp Wood/LC, TX
Read this:I went to the truck today and I am starting to understand what you are saying.
The problem is I don't know which leads are positive and which leads are negative.
The only wires that are color coded seem to dead end at the NATO plug.
I am trying to lift the cab (hand pump) to trace things out but I have a nut that is leaking fluid hydraulic. It is a huge nut located between the cab and the bed. I tried to tighten it but it has a whole in the center that allows fluid to leak.
https://www.youtube.com/watch?v=2R5mtn0KAFo
If you watch this video pause it at the 13 sec mark.....the nut in the middle of picture is leaking fluid. Sorry for the confusing description. How do I stop this from leaking so that I can raise the cab and get the battery wiring figured out.
Thanks
http://www.steelsoldiers.com/showth...V-PM-not-covered-in-TMs&highlight=critical+pm
