Another helpful LMTV tip regarding the air governor
scottmandu
36
Texas
I was having an issue with compressors on my A1, one broke a rod and the replacement was extra "Rattly". I also noticed the air pressure guages were pegged to the right and there was a constant bleed of air at the rear of the truck.. Well I replaced the air governor and all of the above went away. Best part is the governor is a $30 part and can be had at most major parts houses.
Reworked LMTV
1,174
TN
Can you be specific about which part houses? Thanks!
