sermis
- 17
- 38
- Temple, TX
I can get the Hemostats on the glow plug Tip, I can feel the tip move around. Problem is the tip is hitting the back of the chamber and still in the hole at the same time. Hemostats just slide off ever time I try to lift it out. Tim has an idea to use somethin curved and go under the tip and see if it will bend enough to come up and out. that would be a lot easier than turning a bolt and trying to force it into the hole.
Temp was 21 this morning and with only 7 glow plugs working the truck started right up. I'm tempted to just call it a day and only run with 7 glow plugs.
