Post a picture or price sheet for us to see.try a plumbing and heating store those are used in fuel fired boiler applications I could go to our local hardware store and get one right now for about 10 bucks.
Good info, Thanks Rusty.
Valve Function | Backflow Prevention |
For Use With | Diesel Fuel, Gasoline, Oil |
Activation | Pressure Driven |
Connection Type | Pipe × Pipe |
Connection | Threaded NPT Female Inlet × Threaded NPT Male Outlet |
Pipe Size | 1/2 × 1/2 |
Maximum Pressure | 500 psi @ 70° F |
Min Opening Pressure | 1 psi |
Temperature Range | -20° to 180° F |
Shape | Straight |
End-to-End Length | 2 1/8" |
Mounting Orientation | Any Position |
Material | |
Body | Brass |
Seal | Fluoroelastomer |
Valve Type | Check |
Check Valve Type | Spring Loaded |
Flow Coefficient (Cv) | 2.4 |
