- 4,400
- 4,181
- Brentwood, Calif
I would call....I thought it said it was void after 11 days after receiving the vehicle???
Even if it is void after 11 days. They only do and warranty that it moves: Operational test is limited to low speed in a confined flat area without load. Differential interlocks, full transmission shifting and functionality of all drive axles cannot be fully verified. Inspector listens for abnormal noises, observes leaks and notes physical damage.I thought it said it was void after 11 days after receiving the vehicle???
Do you mean the fake door (filler panel)?I can't figure out how to get the driver rear panel off. I looked at the service manual but it looks stuck. I see one steel line attached to it but it isn't a factor. I beat on it a little with a rubber mallet but don't want to hurt anything. What's the easiest way to get this thing off? I need to check the tcm.
Yup, he can access the relay to reset it the same way he has to get to the TCM.president camacho, Shoot me a PM and I will send you my number. I have run more 1123s through my shop then probably anyone. Got some Ideas for you. There is a circuit breaker and a transmission relay behind the battery box unfortunately the way that roof and rear wall was designed makes it very difficult to access.
Or just take the bench seat off. That door removes much easier by raising up the back end and sliding the flap oyt from the wall. But your bench seat is in the way of that. All of this is part of the reason I try to keep my stuff AMGeneral parts.Action, I can't get that flap out from the rear cabin. The bolts and that 1/4" turn bolt is out but there's no way the flap will be able to clear the rear cabin wall. I may have to remove the rivets in the piece that hold the 1/4" turn bolt, remove that assembly, and it should be able to come free by doing that.
Congrats, get to know it and have fun with it.. Yes, there are lots of members with vast knowledge on this forum. We are very lucky to be able to pick their brains on this unique vehicle.Want everyone to know I've finally tackled the problem with help. Mjvaden talked with me over the phone, sent pictures, and texted everything that needed to be done. I now have an m1123. I couldn't be more happy. He solved the issue!!! I also want to thank everyone who threw in helpful comments here at the forum!
AND HERE IT IS! ME HAULING ASS!!! WOOOT! Mjvaden knows his sh*t.
