Migginsbros
- 6,360
- Berlin-Germany
Originally Posted by lummi
Did you ever figure out why the RPM switch wasn't working? I am having the same problem. Does the tools switch need to be engaged for the hi/low switch to work? Also, what is the part number of the Cole Hersee tool switch (broke mine trying to clean terminals). Thanks
your system to let the air cylinder work.
Today we tryed out the funktion of the two switches on the hydr.oil cooler desk (Hi/Low + RPM) It is not neccessary to engage PTO for both switches to work. But you must have airpressure onIt is not neccesary to pull the tool switch for the rpm or hi/low funktion on the backhoe fan desk. The tool switch give pressure to the tool hoses and parallel rise rpm.
Perhaps...... the hi/low and rpm switch on the fan desk is only in funktion with PTO (for the backhoe) engaged. We will check out next time.
