123pv
- 0
- 1
- GreenwellSprings/Louisiana
I live in south Louisiana. 90 degree days are every day. is it possible to install a biger Radiator? I did put 35 inch tires on my truck. I think transmission cooler would help.
If you have the M1008 radiator then you have the largest radiator ever made for this truck. It is a 4 core copper radiator and it's over 4 inches longer then a civilian model. Unless you specified at time of purchase the stock radiator is much smaller.I live in south Louisiana. 90 degree days are every day. is it possible to install a biger Radiator? I did put 35 inch tires on my truck. I think transmission cooler would help.
Post some pics of it.I installed a aftermarket rad that is twice the size as the original (cores). The Tanks are bigger too. I got it at a local Rad shop in Houston. It's all aluminum. Tanks and cores. I also swapped the 5 blade fan for a 20 inch 6 blade. I'm running a 180 deg Robert Shaw thermostat. Temps here in SE Texas can get a CUCV pretty warm. It never overheats now. I got it to 185 once while towing my tractor. I do have trouble in the winter getting it warm enough though.
