- 6,426
- 4,985
- Ft. Lauderdale, Florida
Do you mean the new one listed at invasionautoproducts or the rebuild at midwestturboconnection?Interesting! I wonder what application the Chinese use these turbos in.
Either one, unless it is simply an aftermarket manufacturer.Do you mean the new one listed at invasionautoproducts or the rebuild at midwestturboconnection?
This was the outfit I was getting information from. I called them today and they do not have the kits on hand but can order them in. They are made in the UK.doghead does it again! $450 for a rebuild.
Thanks doghead
You can spend some quality time here if you want to make absolutely sure, but according to Alexander this turbo would work fine here. Pretty much the same factory RPM range and CFM needed and with the adjustable wastegate no need to worry about blowing off the heads !This is good info so far, but what about the turbo maps? Long ago, a member here said that just slapping another turbo on will do little if it doesn't have a similar "turbo map".
I don't know much about turbos other than the basics, so I am just going from what I was told in the past.
I forgot to add that if we where going to race our trucks then we would absolutely go by the turbo map. But since we don't really need to worry about "spooling speed" and turbo ratio (exhaust flow to air intake flow) and other minutia we can get by with "pretty close" . Plus we are not using the turbo to it's maximum capability. In fact without the internal wastegate this or almost any other turbo would be too much for our trucks.This is good info so far, but what about the turbo maps? Long ago, a member here said that just slapping another turbo on will do little if it doesn't have a similar "turbo map".
I noticed that too. You have to look at the international trucks of the same vintage. Seems only they used the GT37. That kinda limits the possibility of finding them in a yard since there are a **** of a lot more fords than internationals. I wonder if the GTP38 would work since it's still the same motor?When I look up the stock Ford turbo for a 7.3 Powerstroke, it always comes back as a Garrett GTP38 series.
Looks like a very different beast on the Ford version. The 03-07 6.0 Powerstroke is a GT37 series however. That looks to be a lot closer.I noticed that too. You have to look at the international trucks of the same vintage. Seems only they used the GT37. That kinda limits the possibility of finding them in a yard since there are a **** of a lot more fords than internationals. I wonder if the GTP38 would work since it's still the same motor?
Don't think those have a wastegate which we apparently need.Looks like a very different beast on the Ford version. The 03-07 6.0 Powerstroke is a GT37 series however. That looks to be a lot closer.
Whats that flap on the turbos exhaust outlet? Some kind of exhaust brake?Now we just need a guinea pig to slap one on a truck and see if anything blows up.
EDIT: Is this the turbo we're talking about here? http://www.cardone.com/Products/Product-Detail?productId=2T251&p=rock&jsn=1180
Agreed. The 93-94 non-Powestroke 7.3 turbo actually looks the part although not a GT37 series.Don't think those have a wastegate which we apparently need.
Im pretty sure Sick Liter (6.0) is an electric variable geometry turbo (VGT). Hence the 6.0 whistle?Looks like a very different beast on the Ford version. The 03-07 6.0 Powerstroke is a GT37 series however. That looks to be a lot closer.
