jaymcb
- 55
- 28
- Behind Enemy Lines, Massachusetts
are the 2 cylinders next to each other?
When is the last time you cleaned out the check valve on the fuel line on top of the fuel tank? There is nothing but a screen on the fuel intake in the tank and crud plugs up the check valve. This is a very poor design. The symptoms are white smoke from the exhaust and lack of power, until the engine won't run at all. This check valve is easy to clean, but one caveat is that it is very easy to break the fitting off the top of the tank if extreme care is not taken. The fittings are very tight. When removing the fittings, make sure you use two wrenches to avoid damage. I intend to place a fuel filter in-line before the check valve, but that is a project for another day. Anyone with an M35A3 should periodically clean that check valve as it will definitely let you down.When is the last time you cleaned out the check valve on the fuel line on top of the fuel tank? There is nothing but a screen on the fuel intake in the tank and crud plugs up the check valve. This is a very poor design. The symptoms are white smoke from the exhaust and lack of power, until the engine won't run at all. This check valve is easy to clean, but one caveat is that it is very easy to break the fitting off the top of the tank if extreme care is not taken. The fittings are very tight. When removing the fittings, make sure you use two wrenches to avoid damage. I intend to place a fuel filter in-line before the check valve, but that is a project for another day. Anyone with an M35A3 should periodically clean that check valve as it will definitely let you down.I am having a white/ blue smoke coming out on down shift and cannot get any power...ideas?
