OuttaTheWayPECK
- 0
- 0
- Topping, VA
Need a little help. Not sure if I ran it out of fuel or not as gas gauge isn't a new one. Truck has been starting up fine, running good. yesterday it cut off on me. coasted to stop. truck started reluctantly drove another 100 feet or so cut off again. I put 5 gals of fuel in tank. I got truck home from a tow. I did the fuel system bleed once. fuel came out and flowed into my capture jug while bleeder top of fuel filter was opened. closed it. Engine sputters and sputters. If you floor the gas peddle, it started very harshly. didn't sounds great but ran. The belt squealing noise big time. but the belts looked like they were all turning. I cut the engine off as it was making squealing noise. I'm going to try to bleed it again, maybe I didn't bleed it enough? but would air in the fuel lines make that thing squeal like that? would a bad water pump make a "loose belt squealing noise" ? ... thanks for the help. 1985 cucv J code 6.2. no mods other than a couple simple things. It has a brand new starter, glowplug sylenoid, and doghead, removed resistor off firewall. new alts...
