rustystud
- 2,987
- Woodinville, Washington
Yes, but even more delay then that. Like minutes !
Just spray it on, or spray it on and wipe it off?I have been chasing an intermittent ground or power fault all winter. Last night I went with the shotgun approach and took loose every single electrical connection I could find under the dash, behind the dash and on the firewall and sprayed them all with Dexoit. That stuff is pricey but great.
That little gremlin used to be a yellow car airfreshener.
Guessing that the fresh "done" left a long time ago!That little gremlin used to be a yellow car airfreshener.
LOL... I love the description of the product. I think is from the same company that brought us the Rockwell Retro Encabulator"sprayed them all with Dexoit."
Just spray it on, it has a flushing action then dries fast. Unless I see gunk that has to be physically removed that is all it takes.Just spray it on, or spray it on and wipe it off?
Haha I didn't even notice that. Someone making listing copied and pasted the wrong stuff.LOL... I love the description of the product. I think is from the same company that brought us the Rockwell Retro Encabulator
This is a CMOS 8-bit successive approximation A/D converter that uses a differential potentiometric ladder-similar to the 256R products. This converter is designed to allow operation with the NSC800 and INS8080A derivative control bus with TRI-STATE output latches directly driving the data bus. This A/D appears like memorylocations or I/O ports to the microprocessor and no interfacing logic is needed.
I haveI have seen one on EBAY and it was sometime back so look there.
Just curious, but how far are you from Ft. Drum?Haven't done much lately with my M1008 because I need to go through the wheel bearings up front but last night I had to make an unexpected run for firewood. 8°F and fired up beautifully, no block heater. Meanwhile my smile grows wider when my buddy's F-350 7.3 won't fire without heat lmao.
