I have a couple of studs that need to be replaced on my M101A2 axle. The technical manual TM 9-2330-202-14&P calls this out:
ITEM SMR CODE NSN CAGEC PART NUMBER DESCRIPTION QTY
10 PAOZZ 5306012376844 19207 12354223 BOLT,RIBBED SHOULDE................. 8
UOC:CT1,SPR,TC1,258,263
I have new studs with "19207 12354223" marked on the head, they are the ribbed style with a shoulder, just as the description calls out. However, they don't match what's currently on the axle. The axle has dual threaded studs with 5/8-11 X 13/16" L threads on the hub end, and 9/16-18 X 1.25"L threads on the wheel side. Anybody know what's going on? Do I have an older style configuration that isn't in the TM anymore? Anybody know what the part number is for the dual threaded studs that I currently have, or where I can source them?
Thanks in advance.
Thanks in advance.
