Deuce dies uphill
demonhunter77
alabaster/alabama
So, I was driving my deuce bobber home from getting a full bumper put on the back and she stalls out going up a steep hill to my place. This is the second time a hill has stalled her out. Suggestions on what to look for? I'm not very diesel inclined yet.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
How much fuel was in the tank? Was it diesel? Stock tires? m35a2 deuce? Gear? Speed? How old are the filters? Runs like a scalded dog on flat ground?
doghead
4 Star General /Moderator
1,179
Must be one heavy bumper...
jamboly
Brenham, TX
I would try adding at least another 10 gal of diesel to tank. If that solves problem, replace rubber hose on in tank fuel pump.
demonhunter77
alabaster/alabama
Gimpyrobb,
Full tank if road diesel. 35 degree incline. 3rd gear. Runs great on flat ground. M35a2. As it stalled I believe I was at 5 mph. Fuel filter should be about 4.5 years old with 600 miles on them.
demonhunter77
alabaster/alabama
I would say I saw 5 to 7 mph on the speedo as she started to stall. She was going more lIke 20 before the slope change. In hind sight, yes, I was still in high range. Steepest on road hill ive ever seen. Lmbo. Goes from 20 to about 35 degrees half way up the hill where she slowed and sputtered.
SCSG-G4
PSVB 3003
5,370
3,383
Lexington, South Carolina
Above first gear I don't like to let the RPM's drop below 1500, in the two higher gears I downshift between 1900 and 2000 to keep the air flowing through the exhaust (lower EGT's). YMMV.
demonhunter77
alabaster/alabama
This is where I should've read up more on diesels. Sounds like it's my technique rather then mechanical issues then?
demonhunter77
alabaster/alabama
That's what I'm thinking. I'd downshift sooner.
The operator's manual (-10 TM) covers this.
Talked with another deuce owner who has driven that hill. It is definitely my driving that was the problem. He has to downshift and up the rpm well before I tried. Now I know. Thanks guys for putting up with my silly question.
rustystud
2,995
Woodinville, Washington
No question is silly if you don't know the answer to it. Of course after you get the answer then we will laugh and make fun of you ! Just kidding ! Remember the TM's are your friend !
wreckerman893
Possum Connoisseur
15,629
2,054
Drop into low range well before getting to the hill, find a gear it will pull in that will allow you to hold around 15-1600 RPM (prob third) and let her pull all the way to the top. The engine does not have to be screaming for the truck to be pulling. That is why you have Low and High ranges.
My guess is that there is still some underlying problem since even if the engine stalls out due to lugging it should still not run out of fuel.
But I only been driving these things around 40 years so what do I know.
