Water in engine valley
Barrman
1,782
Giddings, Texas
I can look at the blocks in my class next week. But, somewhere around 1992-1994 when they changed over to the 6.5. The drain went from the small hole at the back with no tube to the bigger hole with the tube.
I like the tube because it puts oil, coolant or fuel leaking over to the side instead of inside the bell housing. Both for leak checking and to keep from burning up a clutch disc.
As as far as the leak itself. Coolant can only be coming from the front thermostat housing cross over which includes the thermostat, any sensor ports, heater hose and the actual attachments to the heads on each side or the two rear cross over block offs.
TOBASH
3,494
Brooklyn, NY
Clutch in a HMMWV?
Wire Fox
161
Indianapolis, Indiana
I need to unclog mine, apparently. My 6.5 GEP just holds water in the valley and I've bailed it out once when it rained while I had the hood open. I'm just glad that it apparently has a drain, because i was originally annoyed, thinking it didn't have one.
86humv
501
Texas
They drain tube goes down forward of the flywheel and is pinched to clear it.
Then its round again and comes out close to the 2ea. oil hose fittings.
Barrman
1,782
Giddings, Texas
No, no clutch in a HMMWV. But thousands of engines from these trucks were sold as surplus. Who knows what they ended up in or might end up in. Someone searching 5 years from now for information about the valley drain might happen upon this thread.
With the older engines valley drain fuel leaking from the IP and running down the back of the block could make people think it is a bad rear main seal. Or cause a clutch to slip. That is why I wrote what I did a few post up.
