spankybear
- 912
- 93
- WA
What and did you make your box out of? Kind of toying with the idea of making one and was wondering what people did.
I wish you could post a linkI have not built mine yet...... but I plan to copy much of Duckworthe's design. I will do thin steel frame with aluminum pre-painted skin adhered with sikaflex. Where I plan to vary from his design is that I plan to run horizontal stringers (hat channel or wood furring strips), then spray foam closed cell foam. Then thin skin of some sort on the inside of that.
Maybe Duckworthe can post some pics of his build here or a link to one of his posts.
Sounds like we have similar versions with a few tweaks, all Duckworthe inspired.I'm getting ready to build my camper building the frame with 2x2 square tubing like duckworth but then going to build the outside out of PVC board 4 foot by 20 foot lengths and cold fuse all joints together I'm a distributor for the product through my Construction Company then going to use foam insulation on the walls with furring strips on the inside to attach paneling essentially making it a completely enclosed capsule.
I don't have a link to his build. I have just seen pictures. Maybe he has a thread or tutorial somewhere.I wish you could post a link
Maybe you should sue for infringement of the copyright.I just wanted something big enough to A) Stand up in and B) Lay down in. This is the back of the first one with one of my tough buddies feeding bread to the WhiskeyJack sitting on the roof. I'll find better pics of the Aero-dyne top on it. I made the top look like the cockpit of a stealth fighter so it gave up that cockpit feeling while cruising down the road. This was back in 1981 so I'm pretty sure the F-117 copied me. I was 6' long, 5'9 1/2" height but only the width of the cab of the 72' chev at 53".
Is it a pdf?I just got a copy of this book.
Looks like a good introduction.
"Build your Own Overland Camper manual (Haynes Manuals) "
No, it is a full length Haynes Manual. I would have posted a link, but it went to a popular online book/everything store.Is it a pdf?
It is a hard cover book. I think I paid $25-30 for it.So you cant copy and paste from it
