- 2,096
- 646
- Orlando, FL
It might be better to move the spare tire to the bed and install a second fuel tank in its place. Trucks commonly have a fuel tank on each side. That will double your range and not make you an enforcement target.
Even with the stock fuel tank, you should be able to go at least 300 miles. That will probably get you out of a danger zone in the event of an emergency. If there is a large scale emergency, I would put whatever fuel tank I need or have in the back and not worry about it. DOT is not going to be stopping anyone fleeing a disaster.
