Rear mud guards for front tires?
Awesomeness
1,518
Orlando, FL
I've seen in some pictures that there are rear mud guards for the front tires. Mine does not have them, but I would like some. Are they only on certain models, or have most just been removed?
Like this (between front tire and battery box)...
Awesomeness
1,518
Orlando, FL
You guys see what I'm talking about, right? The green arrow points to a mud guard, that is not part of the hydraulic reservoir for winch models either. The red arrow points to a truck, like mine, that doesn't have the mud guard, and even happens to show all the mud that gets slung on the battery box. I've seen the LMTVs with the mud guards many times in pictures.
coachgeo
3,447
North of Cincy OH
Sheet metal or similar fabricator kinda fellow can probably make you up one for 100th of the cost of one from a surplus resale place.. cept maybe Will (suprman)
Awesomeness
1,518
Orlando, FL
True. I was also eyeballing the rear metal mud guards, and wondering if there would be an easy way to make brackets to mount a set on the front wheels. I'm sure those would be cheap, since anyone parting out a truck probably has a set they're dying to get rid of.
Suprman
693
Stratford/Connecticut
There isnt one on the passenger side. Cant have much there the winch cable runs along the frame out a few inches. Thats why the fuel tank has a notch at the back bottom.
Awesomeness
1,518
Orlando, FL
I've often wondered why the tank was shaped like that, thanks!
Pointman
I don't know, I've never seen pictures of the other side. My intial thought was that it would basically be the same thing on both sides, just with any changes necessary to fit the appropriate mounting locations. Now you have me wondering too...
Pointman0853
13
Gardnerville, NV
I plan to look more into this part. I've noticed the bracket higher up and wondered in the past if 'something' was supposed to go there.
After off-roading, I get a sh#t ton of mud up in there and its tough to get out of the battery box and air tank area..
Pointman
Awesomeness
1,518
Orlando, FL
Pointman
Yep, same here, which is why when the pictures with the mud guards caught my attention, I wanted to know more about them. I'm going to be swapping the engine in my M1078 soon, but after that I may design up some guards that bolt on and see what they would cost to get made. It might be worth just having them professionally made, if we can get the cost down because several of us bought them.
Awesomeness
1,518
Orlando, FL
I love to see what the part number is for the turbo on the 290HP engine...
Pointman
I can tell you once I get it. However, it may be the same as the 225HP model. I know some people said the engine has several different internal parts (e.g. injectors), but I don't remember if they said it had a different turbo or not.
