Csm Davis
- 393
- 83
- Hattiesburg, Mississippi
I think it is board flat, which is how mine will be with just an inch of drop to the front and the side slopes will have a inch or so over hang past the windows so no rain gutter needed. The back window on mine will not open and probably have a mesh wire or expanded metal cover. Mine will be taller than stock, tired of bumping my head, and to clear the ROPS kit I plan on doing, my front windshield will be taller than stock also and non-folding or opening. I do think I will put some lights under my visor area.Okay, the HET look is cool!!
Jeff, do you happen to have a couple of pictures of the top of the HET? It seems that it's flat, making me wonder what way water would go. I don't want it coming toward the doghouse. If the center has a slight crown, it would drain to the side. I definitely don't want a "pool".
If it were higher on the front (than the windshield), it might make an interesting place for some lights. Same thing in back (for lights). It sure would make forming easier if the front and back had a duck-bill and I used the square lines of the HET. I would still roll the back to match the cab. Making a side overhang would not be out of place either.
Do you happen to have a back window (military surplus)?
Sent from my SM-G930V using Tapatalk
