peakbagger
- 359
- 63
- northern nh
I haven't been in as deep as you have but I believe that sleeve is common wear item. I think Scott at EI has one listed (but I have not checked the part numbers!)Not so sure about the pinsView attachment 675792View attachment 675793View attachment 675794
I think I found the culprit to the leak on the transmission. This little culprit was dropped into the bottom of the plastic receiver, (from whoever worked on it previously) so the gear shift didn't sit all the way in, and tore up the plastic sleeve. Thank goodness it didn't drop into the transmission, and tear it up. We'll see if this stops the leak. It's hard to believe that this steal pin was worn out, and needed to be replaced with only 675 hours on the machine. It must have been a lot of reverse and forward shifting.
