- 6,075
- 4,450
Governor? Or unloader?
Meant to say unloader hung.Governor? Or unloader?
Thanks for the weather update, as long as these tires hold I think she'll make itJust saw you were down, then back up again. I was only an hour north of you. Glad you got it going again, and maybe you will miss the rain. The front is now along the I=65 road between Mobile and Montgomery, AL
Download the p2p program so you have an air diagram. 95 percent of the time its a diaphragm. Especially if you dont know the last time they were changed. Buy good caging bolts and do all 14 diaphragms one weekend. Takes about 2hrs and 30$Sounds good Simp, I've got a Q2 coming in hot at the local O'Reilly just in case, and I when I get home after work I'll do some leak testing; I do commercial refrigeration and we've got some awesome leak detector mix
