Kasper31
- 0
- 16
- South East Michigan
I just got off the phone with a fellow from ( Maradyne Air O Matic ) so here is some info for those of us with air steering assist problems. First, he says that the "Torque Valve Assy. " that is part of the drag link is NOT repeat NOT rebuildable and will be distroyed when trying to take it apart. In most cases ( not all cases ) the valve will leak air because the accuating cylinder on the axle has failed and is passing air thru it because the special O rings have failed. There are parts available and the cost for the Torque Valve assy. is $847.55 no exchanes, the cost for the piston assy. $1254.65 no exchanges.
I'll have more info on Monday when he send the parts list and some drawings showing the breakdown of the units.
Gimpyrobb is correct, yes you can rebuild the air cylinder, however you will distroy the Torque Valve assy. when you try to get it apart.
